oh jeez.. an odd noise
2003renegade
South Beloit, IL
when i step on the accelerater there is an imediate noise. it sounds like a cricket. it only does it when i step on the gas and then it goes away. its very annoying. anyone possibly know what this noise could be??!!
Bikeflyer
Strasburg, PA
Get a mechanic's stethescope and Carefully listen to each pulley as it runs and you will find the squeak. If it is the idler(which is most likely) consider replacing it. Also check for serpentine wear. If the groove side is cracked, replace both the idler and belt.
