4x4illustrator
Ok guys, so I decided to tackle the front struts. It took me forever to get the passenger's side completed, but now I know the trick of it....and I don't think this is made clear anywhere because I've searched and looked in vain.
The major and only problem was separating the bottom fork from the strut assembly.
First I unbolted the upper ball joint and gave the knuckle a whack with my sledge. Next I unbolted the pinch bolt on the fork, then the lower fork bolt. I broke the retaining clip on this bolt. None of these bolts came off with my impact gun by the way. I live in the north east and my Libby is 11 years old with original equipment. I sprayed all with Deep Creep (love the name). Everything had to be cracked with a breaker bar and pipe. I kept the assembly bolted in under the hood.
Now to separate the fork from the assembly.....There just did not seem to be enough room to do this. Finally I took a long heavy digging bar (5' long steel bar) layed it on the bottom control arm and pried this down by stepping on it.
Voila! So Easy!
There was easily enough room to pull off the fork! I then unbolted the old assembly and installed the new one. Stepped on the bar once again to lower the control arm and inserted the assembly into the fork. No ratchet straps or removal of other components.
Now I just have to replace the lower bolt on the fork, and tackle the drivers side. I am by no means a mechanic but I can count this as one more successful repair with my own hands because of the great info coming from this forum. Thank you all.
Voila! So Easy!
