motor swap 2003 into 2002
dougal
rhode island
new here looking for help an direction ? just finished putting motor in been doing it a little at a time over 3 months been nothing but trouble. would never do again.was going to try to start but when we put battery cable on, the starter motor seems to b .is there something we did backwards with starter or is this just electric gremlins ?by the way i am a real novice at this. any help or direction would b appreciated.thx
JasonJ
Michigan
Hmm.. not sure how much assistance I can give with that description. Did you use the 03 or 02 wiring harness?
It sounds like the wires for the starter are either swapped around, or shorted to B+. That is much more likely than the ignition switch being stuck or shorted in the START position.
What parts were swapped over from the donor car to this one? Was this just a long block swap?
