LT/load range E tire pressures
Myke
USA
If you're running an LT load range E tire what psi are you running them at?
With my 265/70r17s I did the chalk test and I'm at 29psi cold with about a 1/4" - 1/2" of chalk left from the edge.
Is it safe to run them on the street with 26-28 psi cold or should I stay at 29 cold?
Sent from my SM-N910V using Tapatalk
u2slow
BC
I run 30psi in ours. Two sets of 245/75R16E.
Really depends on your KJ's weight.Your pretty light without any armor.
When my KJ was still IFS with full armor(5500lbs) the 2 sets of 265/75R16's(load range D) was best at 38-40psi.
Cardhu
Great White North
My 245 75 16 C's liked 34- 37 PSI. I was pretty light.
how bad does the chalk look at 33?
You'll have less chance of issues at a higher pressure than the heat associated with under inflating.
Just don't let anybody convince you that you need 80 PSI like a 2500 series truck.
