lower rad hose clamps
RenKJ
Canada
anyone able to advise which of these clamps would be for the lower rad hose on a 2006?
mopar is telling me a worm gear clamp is correct for my ride, but my current clamps are constant tension
The problem is the OE clamps are no longer available, which is why they mention worm gear clamps.
If you can re-use the original factory clamps again, that would be the best solution.
Keep in mind there is a cable type tool for removing those clamps. I'm sure some have used channel lock pliers to remove the OE's tho.
Would also be a good time to have the new Mopar thermostat & lower rad hose in hand as well.
kejobe
NE Ohio
I just use the worm gear clamps from Home Depot. They’re stainless and I’ve never had an issue with them on anything.
