Longer sway bar links
Patrick_lang2013
Update on the extended sway links...
Teraflex makes sway bar links for 3-4” lifted JK that fit perfect on the rear
Part #1754500
For the front... I have some WK sway bars links that have been modified. They are a little longer but will still work. I had them bent to match the factory front links.
No issues with either front or rear and handles better than before.
Crown doesn’t seem to make custom brake hoses anymore...
So now i’m waiting for Pirtek to finish up my custom order SS Braided brake hoses, i’ll have them ready by Tuesday.
(Btw my 5100’s, the circlip is on the very bottom on #1 and I had a custom made strut mount similar to what comes with the Daystar coil spring spacer lift. I also have two conduit lock nuts on each side)
Still rides smooth. No issues
Patrick_lang2013
IG ???
Instgram ?
about as bad as fakebook with some
have they actually built any ?
seems like 2.5 is kind of small, have to remeasure mine
length depends on how the shocks are build and how much thread you have to work with
Do you have JBA adjustable coilovers?
