Left blinkers stopped working
Jasonmc
I thought I would post to help anyone with this problem. My left blinker stopped working on my 2006 jeep liberty. It’s fairly well known that the flasher is inside the hazard button on this, and there is some YouTube videos on how change it. There is a relay for each direction inside the hazard module so it is possible to only have one side not working. Also, the green indicator light in the guage pod did not blink. Also, the left did not work when using the hazard mode or when pushing the lock unlock button that blinks the blinkers. Also, any position of the multi function switch behaved the same with hazard mode. These tests may help someone pinpoint this issue
  • Like
Reactions: klc
6ixJeeper
Toronto Ontario Canada
This happened in my 06. 7 years ago It’s a spring or clock spring that’s the issue. I got the part from a junked lib
  • Like
Reactions: klc
Jasonmc
The flasher module was the solution in this case
