Luke
Interloper
We can't ... he has the JBA adjust-a-thingy-ma-bob
All we can do is beat it into submission ... :happy175:
He does? When did they start making them with black springs and yellow shocks?
...Guess I need to go beat on the suspension a bit next weekend...
No, Luke was referring to TomMudd's KJ - he has the JBA adjustable coilovers.
Wheeee32, do you have the Frankenlift? If so yours is a bit higher thanks to the Franky parts. Luke is right, beat on it offroad to break things in and it will settle just a bit.
If you don't have the Franky...Do you have a spacer on to of the shock tower? Do you have conduit nuts on the bottom of the shock (clevis lift)? If you have three in there you can take a couple of them out and that will drop it 1/2". Remember, you'll need an alignment then.
For a_ibrahem, that suggestion goes for your your KJ as well. The JBA arms are supposed to eliminate contact with the springs - but if you're too high then they will still hit. Not good.
Describe your lift setup for us. We can see the OME springs and Bilstein shocks; what spacer do you have on the top of the shocks? How many conduit nuts on the bottom of the shock? What do you measure from the center of the hub to the bottom edge of the flare?
I have that issue on mine. How do you lower them back down?
:ban:
Hi Bob,
I have OME HD complete setup coils and shocks with 20,000 KM on them now ,and yes I have long bump stop and its touching the UCA when traveling up.
I have no spacers on top, just 7 mm ring bottom of the shock, but I had the same issue before installing it also (didn't do allighnment after installing it)
It sets now on 21 inch four corners.
Appreciate you advise
Should always do an alignment ANYTIME you change anything on the suspension. there is one issue there. If you are only at 21 inches then something else is wrong since that kind of contact is usually only found when you lift too high
I actually think it being out of alignment could be part of, if not the issue.
Agree if its out far enough it could possibly sit the entire assembly in somewhat
also i wana know ,in the alignment the springs can move closer or away from UCA ?
Yes moving the LCA (during alignment) will change the relative position of the spring. Whether it is enough to solve your problem... :shrug:
Limiting strap for that kind of activity but you will lose your flex.
No,When installing the jba 4.5’s, is there any trimming that needs to be done to the pockets? Don’t seem to have a lot of travel.
