PunkChachi
So I have an 04 Liberty 3.7L V6, bought it in 2012. Since then I have had maybe 5 ignition coils go bad. None of them went bad at the same time, sometimes it would go a year without one going bad. (Also they always tend to do it it cold weather). Well last month the check engine light went on, got it read at AutoZone and once again a coil went bad, #2 cylinder. I went to try to start it up later that day and the engine started shaking from missing on that cylinder and wouldn't start. I have been dead broke so I didn't have the money to buy a new coil (I know they are only $20 but I didn't have it) so my Jeep sat for about a month. I bought an ignition coil today, put it in and the batter was dead. I hooked up to my GF's Nissan Versa and it wouldn't start. I cleaned the terminals to clear off the corrosion (got a better connection) and I could hear it want to start. Now and then it would rumble for a second but never turn over. So I gave up and took the battery to AutoZone and the meter showed it at 11.85 Volts. He said he could charge it overnight and test it tomorrow.
Does anyone have any input that might give me a head start? My first step is going to try cranking it with a fresh battery. If it starts, awesome but if it won't turn over what could it be? I'm going to pull the plugs tomorrow if it doesn't start up. Thanks in advance.
Also on an unrelated note, someone stole my antenna. There are scratches from the pliers when the ******-canoe stole it.
