I just changed the lifters on the passenger side bank and now the idle is way too high, I popped the hood and noticed I left the IAT unplugged. Plugged it back in but no change. I scanned and got codes for that sensor, plus one for the MAP, though that was plugged in. I erased codes but high idle persists. Thought I might have accidentally disconnected a vacuum line, but I'm not seeing anything. MAP live data shows 14.6 psi engine off and 5.1 when idling (don't know if the latter number is good or not). Thoughts?
I also checked the cruise control cable but that's not causing it.
