Before I begin let me say that I did search and didn't find my exact issue and wanted some clarification on fixes/diagnosis anyway.
(2006 Jeep Liberty Sport)
So here's the problem.....
My HVAC fan works on all speeds (1-4) but the directional options (face, face/feet, defrost, etc) doesn't work -- most of the time. That is to say that in some instances some of the settings will work, partly. Like on the way home yesterday I could get the "face" vents to blow a LITTLE air out, but not the correct amount. The rest sounds like it's blowing in the dash, behind the glove box.
When I got home I opened the glove box and looked behind it to see if something had come loose. Nope. I also checked under the hood for any obvious problems. None. I then shut the hood and tried the face vents again. They were working about 80% of the normal volume. So I turned everything off and tried again. At this point it was stuck in defrost again.
So, I've searched and searched and haven't found a DEFINITIVE solution. But I did see a couple of posts in these forums which mention the vacuum line. This sounds like an easier fix as the other "fixes" indicate full dash removal
So my questions are:
1. Is my problem a vacuum line leak? If you think so, with what certainty.
2. If this is a vacuum line leak is this something I can test for? Fix?
3. Would any of the handheld diag computers (like they use at AutoZone) be able to tell me where the failure is?
If there is any additional info that I can provide you with that will assist in troubleshooting/solving my problem please let me know.
Thanks.
Oh and BTW...I am no mechanic by any stretch of the imagination but I am comfortable with changing my own oil, filters, and brake pads (that type of thing).
Thanks.
