Programming a new keyless entry remote
To begin, you will need an existing (WORKING) remote, and the new remote(s) you want to program.
If equipped with VTSS, the system must be disarmed and/or unlocked to enter program mode.
Warning:
Simultaneous programming of multiple vehicles should be avoided as any transmitter activated within 30 meters (100 feet) can get programmed and may result in cross-vehicle programming.
Part Number for remote: 04602260AA
This info was taken from http://dodgeram.info/tsb/2002/08-007-02.htm and has been distilled to only apply to KJs
- Press (LOCK) button 5 times at 2 second Intervals to resynchronize transmitter, Attempt to function transmitter, If working as designed discontinue programming.
- Turn ignition to run position, (Allow Ignition chimes to stop).
- Using any original (working )transmitter, press the [UNLOCK] button for 4 to 10 seconds.
- Within the specified 4 to l0 seconds, continue pressing the [UNLOCK] button and press the [PANIC] button for 1 second and release both buttons. A chime will sound to indicate that the transmitter programming mode has been entered (allow 3 seconds for chime to sound).
- Press [LOCK] and [UNLOCK] buttons simultaneously for 1 second and release.
- Press and release any button an the same transmitter and a chime will sound after successfully programming the transmitter.
- Repeat steps 5 through 6 to program additional transmitters.
- Turn ignition to OFF position. Transmitter programming mode will discontinue after 60 seconds. (All transmitter programming must be completed within time specified).
Warning:
