help help
wo shi
china
am from China, my car is the car jeep liberty in China rarely only about 40 or so cars now each of my car ignition time history of will jump 6ASCAP click can clearly predecessors I would like to ask you this is why I am very anxious thank you because my English is very poor so use translation software to be answered liberty in china is very little
04Liberty
MD
检查你的气顶,你以后的燃油单击它在真皮休闲包5倍。如果“ gascap ”依旧,更换气帽。检查你的气顶,你以后的燃油单击它在真皮休闲包5倍。如果“ gascap ”依旧,更换气帽。More
Jiǎnchá nǐ de qì dǐng, nǐ yǐhòu de rányóu dān jī tā zài zhēnpí xiūxián bāo 5 bèi. Rúguǒ “gascap” yījiù, gēnghuàn qì mào.
04Liberty
MD
Hopefully Google translate got that right lol
wo shi
china
Has replaced the oil tank cover but the problem still exists to help Thank you
oil tank cover 和 gas cap 不一样的.
你 已经 换 了什么?
English:
oil tank cover and gas cap aren't the same.
What have you replace?
wo shi
china
你 已经 换 了什么?
English:
gas cap in CHINA GAS CAP IS TANK COVER you say gas cap is The cylinder has a screw thread. I replace this I BUY 2
wo shi
china
peeps my chinese isn't that good but I'll try to help so just post in english and I'll translate.
thanks I am very worried that I like to cross the road, but the problem is not solved the car as my children, I have more than 12 points in the evening and I am waiting for the effective way
twowings
Tulsa, OK
Replace the Leak Detection Pump by the fuel tank....if that doesn't fix, replace the Purge Solenoid next to the battery...this assumes that your vehicle is so equipped...
wo shi
china
I M 07 jeep liberty no Leak Detection Pump Purge Solenoid is new buy USA
wo shi
china
在汽油箱附近有一个 'Leak Detection Pump'.
试换出来.
如果还有问题,试换 'Purge solenoid' 在电池旁边, 如果您的 Jeep 有一个.
wo shi
china
试换出来.
The gas cap message could also mean Large Leak detected.
Look at around gas tank where all the lines connect into the tank & look for any cracks in lines, vent tube lines, filler neck etc.
Hedsic
Des Moines, Iowa
The message will not just go away as soon as you put a new gas cover on(or if it does it usually takes several cycles). Disconnect the battery and reconnect (clear the code) and see if it returns after replacing the gascap.
The big questions is, how does the vehicle run? Does it behave normally?
该消息不会走开只要你把一个新的燃气盖(或如果这样做,通常需要几个周期) 。断开电池并重新连接(清除代码) ,看看它是否更换gascap后返回。
最大的问题是,如何在车辆运行?它是否正常行为?
Gāi xiāo xí bù huì zǒu kāi zhǐyào nǐ bǎ yīgè xīn de ránqì gài (huò rúguǒ zhèyàng zuò, tōngcháng xūyào jǐ gè zhōuqí). Duàn kāi diànchí bìng chóngxīn liánjiē (qīngchú dàimǎ), kàn kàn tā shìfǒu gēnghuàn gascap hòu fǎnhuí.
Zuìdà de wèntí shì, rúhé zài chēliàng yùnxíng? Tā shìfǒu zhèngcháng xíngwéi?
