Harbor Freight Tools
djtimyd
Colorado
This here is a can of worms - I know...
I am specifically talking about THIS compression testing kit.
I bought the kit because it had all the screw in connections, rather than those rubber hold-and-hope jobs that the other kit has. I am testing the compression on my XJ by myself so I had to have the screw in type, and I also don't trust the hold in place types. Needless to say - none of the fittings... uhhh... fit the jeep. I thought that it was initially a SAE/metric issue, but the 4.0L in the XJ uses 14mm spark plugs and I had a 14mm attachment. I read and reread the instructions and it mentions an adaptor for deep well plugs, but it doesn't come with this adaptor.
I drive over to Advance Auto to rent a tool - but they don't rent compression testers. Needless to say, they have lost me as a customer. The sales person behind the counter looked at me like I was crazy for wanting to rent one, rather than buy there $89 kit. So I drove to AutoZone.
They had a basic kit with the extension for 14mm deep well socket for rent. I used it and it worked like a champ. Super easy to manipulate and use. Tested all cylinders in about 45 minutes.
On the last cylinder, I thought that maybe with the extension this Harbor Freight kit would work just fine. I screwed the extension on and tested it - but I got ZERO psi. I kinda freaked because that is bad bad news for compression. I took the Harbor Freight tester off, installed the AutoZone one, and it read just fine. I reinstalled the Harbor Freight one thinking that I must have done something wrong... and it still read zero. So even with the adaptor, the tool failed to work at all.
I love Harbor Freight, but I think from now on, I'll stick to the cheap hand tools and free flashlights. I give this product zero stars to match the ZERO psi it wasn't reading.
I would be curious if anyone else has had better luck with anything that is more complex than a hammer or a socket.
I have had their sockets crack. Broke two 1/2" drive ones. Broke a 3/8" one. Their screw drivers bend like the nile river runs around corners. I had an extention break and the square part that snaps into the socket stuck in the socket. A couple of other hand tools broke I can't remember. Haven't been there in years. I do have one of their larger floor jacks and that has been ok but I usually use safety stands and a second floor jack where needed. I don't want that to give way when I am under it.
I've broken 2 sockets ( regular cheaper ones ) from harbor freight over the years but nothing else.
Of course most of what I use is their impact line of sockets , never screwdrivers, testing equipment etc
YMMV with HF stuff.
Some of it is amazingly good for the price.
Some of it is absolute sh*t.
I have stuff here of theirs i've had for like 14 years (4x8 1100# rated folding trailer. best $200 I've ever spent), I've had stuf last one project (took down a 30' chestnut tree with one of their electric chainsaws), and I've had stuff break right out of the box.
Their "pro" line of hand tools is good, at least for a DIY'er. I have a few odds and ends. I have their Daytona floor jack which is eerily similar to one Snap On sells.
CzarKJ
Townsend, MA
75 buck floor jack works great. 12 ton bottle jack works awesome. 9000lb cable come along works for tensioning rope on trees. Wrenches are a bit wonky. Anything "free" there is to be avoided
Sent from my SAMSUNG-SM-G870A using Tapatalk
Counting My Blessings
I have a heavy duty welded metal yard cart that is awesome, a pressure washer that is very good, and a woodchipper I have not tried yet.
I learned the hard way that, for automotive work, their cheapo sockets are not going to last. The impact sets I've purchase are terrific.
JasonJ
Michigan
I have their 2-ton engine lift (cherry picker)... used it to remove and install engines on perhaps a dozen or more jobs... it is fantastic, especially for the $130 paid.
Their hydraulic tools seem solid; impact sockets, no problem. Drill bits are garbage. The digital dial calipers are great and very accurate. The sledgehammers are great too.
What else... tie rod separator, pickle fork, works fine. The metal clasp storage boxes are good (my wife uses them for her fancy pens and markers). Their towing stuff seems good so far, the $9 HVLP paint sprayer works fantastic for cheap or small projects.
Like was said, some gems in there and some trash... it's not all junk. But some of it is best left on the slow boat to China.
03silverrenegade
Ashburn
Stay away from their ac manifolds too. They're good for maybe 2-3 uses.
I have one of their aluminum floor jacks. Its been great for the past several years.
If you use a tool once or maybe once a year HF is still a bad choice.
I use my tools everyday at work,once all where switched out for Snap On,Matco,Cornwell,and MAC(with a few other brand names without mobile tool trucks) I rarely ever break a tool anymore besides drill bits/extractors.Think the last tool I broke was 3 years ago but you expect that when you pay prices like $500+ for a 10 piece wrench set(10mm-19mm).
Have over $100,000 in tools and won't even walk into a HF,which is 1/2 mile up the road from my place.
JasonJ
Michigan
All true, I'm STILL using my dad's Snap-On and MAC tools that he bought in the late 70's as a VW tech.
BUT, HF is not geared nor intended for people like you, Troy.. you're way too professional to be their target customer.
Heck I'm still using Sears, S-K and Wright tools I bought back in 70 and 71
well along with later tools bought due to metric etc but mainstay are ones bought back then.
just an added thought, bet my jeans and a lot of my tools are older than a lot of folks on here !
Not sure if thats good , ....or sad ?:emotions34::icon_razz::icon_razz::gr_grin:
JasonJ
Michigan
I have S&K tools as well, circa 1977. Dad bought those as well- love them.
As to the pants... well, I guess it's a good thing that they still fit, right?
turblediesel
memberable
Alaska
In my recent research into HiLift jacks I came across a strong recommendation against the HF lift.
Old craftsmen sets still serve me well. Many pet tools that I've had a long time that never failed me.
I wear out jeans as fast as I wear out gloves, boots, and socks. Constantly buying new.
I bought a 14" chain saw at HF on sale for $40. Has done a good job so far. If I anticipated having lots of wood to cut on a regular basis I would have gotten a better one, but for what I'm doing I think this was a good deal.
JasonJ
Michigan
My HF 8# sledge hammer has been great.
The $8 plastic saw horses have been plenty useful....
There is a time and a place for Harbor Freight.. but I would hesitate to say that it should be anyone's primary source for their main tools. If that's all you can afford... I'd buy them as temporary tools until you can get better ones, or ask for them for your birthday.
I have a S&K 1/2" drive ratchet that is older then me and works better then any new MAC/MATCO ratchet,much smoother also.Now it can't touch the Snap On 80 tooth ratchets but comes close.
Not so well anymore, middle age widening :happy175:
Those are sweet......
What about the new dual pawl 90 tooth SK ratchets? I've been thinking about getting one. I'm a fan of SK stuff for some reason.
