GeekFisher
Hi guys,
As earlier stated, I bought the Jeep to go on fishing and hunting trips.
I planned on doing some enhancements it
For the tires, I settled on BFGoodrich All-Terrain T/A KO2 in 235/70R/16, just a tad larger/higher than stock 215/75/R16. I like them so far, they are great in snow and not bad in icy condition as long as you are soft on the pedal. Also gas mileage did not seem to suffer much and ride comfort is exactly the same.
I also bought an Android "double-DIN" unit which is great but I had lots of triming to do to make it fit both the dash and the Metra kit. I finally painted it silver as I thought the Jeep interior was a bit too dark.
I finally painted the plastic silver and it's not that bad. I have yet to receive the OBD-II Bluetooth and the flushmount USB ports.
I received the Cobra 19 DX IV CB I ordered but have yet to receive the 36" antenna to match it.
I also end up painting steering plastic and shifter surrounding trim. The steering is nice but the shifter trim not much:
It's going to the paintshop this week-end for the rockerpanels and another spot close to the third brake light.
I had the P0725 a few times but cleaned contacts and so far so good, drove it for a week and went great.
Also, every so often I do have a burn plastic smell from driver side underhood, is it possible that some wiring went lose and is touching hot parts ?
Another question, I'd like to change my backwindow brake light for a led one to be seen when doing wood road in dry weather (which generate LOTS of dust) which bulb do I need ?
Thanks,
- Change tires
- Change head unit
- Add CB
- Rocker replacement and some rust spot correction
- Roof rack
- Fog on high beam mod
Thanks,
