prionicone
Has anyone tried installing those on a domestic KJ?
I've got a 2007 and was thinking to get a set as well as the leveling switch/dial for the dash to upgrade to the "Export Headlight Leveling System"
May need a different wiring harness as I assume the domestic harness doesn't have the correct wiring for this? I'd have to check the various wiring harnesses and which lines they were installed on?
Looking at the 2007 KJ Parts Catalog pdf, there are a few different model numbers depending which line built, region, and series the KJ is apparently. All models have the same Body info.
Right Export:
55155812AD:
Line J = 4WD
Series: H,P,M = Highline/Premium/Medium
Body: 74 = Sport Utility 4-DR Type #4
Engine: EK0 = 3.7L V6 Engine
Left Export:
55155813AD:
Line J = 4WD
Switch, Headlamp Leveling:
56010204AE:
Line J,T,U = 4WD, 2WD, 4WD RHD
Series: none listed
Engine: none listed
Right Export:
55155812AD:
Line J = 4WD
Left Export:
55155813AD:
Line J = 4WD
56010204AE:
Series: none listed
Engine: none listed
