Hey guys, desperately need help with the 4th wire in my EVIC install.
I have the link to the famous OTIS/EVIC thread, but it doesn't tell you where to splice the last wire. He simply says to find a wire that's hot when the ignition is switched to "on". Aren't you supposed to have the battery unplugged when doing electronic mods to your car? How is it possible to find a wire that's hot when the battery is out? I don't understand this huge hole in an otherwise awesome write-up.
I'm at the tail end of my power steering pump install and I had the battery and tray out to get the pump out. Got it back in, and I figured I'd go ahead and finish the EVIC wiring. I'm one wire away from completion, even got my temp sensor installed. Any suggestions/help would be appreciated.
