Engine Performance Upgrades
streetsnake
I’m curious to know if there are any recommended mods that can easily be done to help increase HP/Torque/responsiveness. Or would money be better spent on driveline improvements. Just kinda curious.
The oem air filter box work very well, you might pick up a few extra HP with a less restrictive exhaust.
I spent my $$ on an OME 927/948 spring lift with JBA 4.5 upper control arms etc. It rides now like a smooth sports truck!
What drive line improvements are you referring to? Re-Gear or aluminum drive shaft etc?
Doing quality lift and larger tires then a regear
Then enjoy , Libertys will never be confused with a HP Mustang , not what they are built for
streetsnake
Yep. You’re exactly correct. I
gotcha. I have all the lift goodies coming. I was thinking gearing and lockers. i Probably wouldn’t go that route as we don’t have a lot of good off-road spots here. I’ve heard the magnaflow is the correct exhaust if we ever get an aftermarket one. :)
duderz7
Weiser, ID
I don't know?..some jack'a'nerple on fb told me my kj was more mustang than jeep? I seem to remember you've mentioned running a small tube from airbox to behind grill? Worth doin? Details on setup?
Magnaflow does well, sounds good plus the fact you can still talk to people riding with you
some like flowmaster have a real loud drone at highway speeds
Just a piece of 3 inch flexible tube from left side of the grill ( looking at the Jeep from the front ) running back into the airbox with hole cut into the airbox in front
Not sure how much it helps but I do know when you rev it up with hand over the end of the hose you can feel it suc king the air in
On the 03 since I don't do very deep water crossing any more , the hose goes down through the hole where the washer bottle was, to just behind the bumper
04 comes through grill
I run Trutracs front and rear in the 03
The 04 I have had a mixture of ARB/Trutrac, both ends Trutrac etc
stay away from lunch box lockers ,
Blue Gen
What about a Jeep Liberty Performance Chip? Vortex..ck online. ? Might be BS ?
NavyStore
Everett, WA
I added a K&N Intake to mine, and the performance was night and day! No dyno results, but the launch when you hit the gas is instantaneous and she's gone from slug to jack rabbit, but I did lose about 1MPG overall. I didn't need to go overboard on mods, (I flat tow it behind my RV and daily driver to work) but this was just what I needed to get out of my neighborhood and onto the nearby State Highway.
Davo1
What's everyone's thoughts on a throttle controller to improve the engine responsiveness ?
One of the best airfilter according to many tests over the years is NAPA GOLD filter
One of the worst , K&N , They are great for short runs like on dragsters etc , but longevity, no
Just a word of advice
Just hangin' out.
Snorkel and Apollo intake got my wife cussing first time she drove mine after installation. Not much different than her stock, but noticeable. Disclaimer, this set up requires religious preventative maintenance so is not for everyone.
Anytime you do a mod to any vehicle it reacts like its completely changed
On KJs just remove both battery cables, tie them together for 30-40 minutes
hook them back up, pull out on the road and drop the hammer
You'll swear it has 100 more HP , it will stay that way for a while then it relearns
you're driving habits
I used to have to drive downtown Columbus ( Ohio ) daily
Before any trip I'd do that and it ran a whole lot better
But was it in my head or ??? LOL
KKinTexas
US
I have a Gibson exhaust. Better sound, no drone. Felt a little better off the line, but it's a Chysler 3.7. Dependable, not a racer.
Dutchman61
I now have a Jasper Engine and Jasper transmission in mine. Will be putting in different fuel injectors which are different than the factory ones. But not until I can put a 3 inch duel exhaust with headers on it. when I connected the original exhaust, the engine sounded like it was being choked. So it is rather lod now but it literally launches when I stand on it and it shifts to 2nd gear. I have changed out the Stock air cleaner for a doubled cold air flow set up. Took the insulation off of the hood and cut in vents in the Hood for good air flow. I will have pics up very soon.
Dutchman61
I had to get one of these very reliable batteries for this project under my machinists recommendations because I was stepping up my Horse power about 100 HP and didn't want any low voltage readings when programming the installed motor and transmission from Jasper Engines.. Along with a double filter air induction, performance fuel injectors, A slight larger throttle body,
performance coils and NGK plugs. ?And Yes , this thing will smoke the tires on demand, everytime. I believe I will be changing the exhuast to a 3 inch with headers verfy soon. Seems she wants more exhaust when I get on the throttle. She is dying to open up more. When I am satisfied with the performance and the readouts, I will try to post a video for here.
