Easy way to check for equipped ABS?
Akedos
Elmira, NY
I have been reading through old posts and realized that ABS was an option up through 05. I took for granted that I had it... never realizing I might not. I thought it was prety standard equipment honestly. But I need to replace a hub and now REALLY need to know if I have it so I can buy the right hub. What's the easiest way to verify if I do or do not have ABS? Is there a stamp on the steering wheel or something?
Porkchop
Troy Mi
I wonder how many people know what that really is Tj. Made me smile.
what. just check the old fashioned way.
drive on gravel/dirt, snooki smash brake pedal. if it pulses you have ABS. :D
Akedos
Elmira, NY
So I take it I have no abs then. Thanks TJ. You are knowledgeable as always.
Loki
arkansas
slight hijack here. My old Dodge Ram 1500 just had rear wheel anti-lock on it. the four wheel was an option though. Had to replace a front hub due to a massive bearing failure. Priced a non-ABS vs the ABS hub. The ABS hub was about $50 cheaper. The only difference between the two? The ABS hub was machined for and fitted with the tooth ring for the sensor.
Go figure.....
