Dome light on 03 KJ
mindbomb
California
I went with the light bulb guide and bought a set of 212-2 LEDs for my dome light - it worked fine for the trunk area light but the driver/passenger dome lights are some kind of other bulbs (3 CP text says)..
This is what I bought:
https://www.amazon.com/gp/product/B00NBH6814/ref=oh_aui_detailpage_o00_s00?ie=UTF8&th=1
This is my dome light:
Once I opened it - the driver side light went bad :shrug:
Which product should I buy to get a bright LED replacement for these and how do I get these out?
Thanks
JasonJ
Michigan
Those look like 194 bulbs, which would be correct, as those are technically the "map lights".
mindbomb
California
Uh confusing, so theres
Map light
194
Dome light
212-2
Step/Courtesy light
906
Trunk/Cargo area
212-2
So where's the dome light?
I can find 194 LED lights in ebay for cheap..
JasonJ
Michigan
Map light
194
Dome light
212-2
Step/Courtesy light
906
Trunk/Cargo area
212-2
Not sure about other KJ's, but the only thing on the interior roof of mine that could be construed as a dome light is the rear cargo light. I don't have a dome light in the middle of the front/back seats where a dome light would typically be found.
Maybe some KJ's without EVICs and the overhead computers have no map lights, but instead a single light that uses the 212-2 bulb. ???
mindbomb
California
No idea, anyways I found 194 LED lights in eBay for 75 cents... I'll report back with results once it arrived and installed.
Myke
USA
I'm interested to see if you get a glow while the lights are turned off.
mindbomb
California
Seems like rear is behaving like that. Need to install front and see what happens.
jeeplib05
Ohio
If one does it they all will, they draw too little power which the KJ supplies even when they're shut off which is the reason for the glow especially when you buy cheap Chinese ones
mindbomb
California
Well, it's not really related to chinese/american - LEDs will glow when "off" because KJ will supply some lower voltage even when switch is off - solution is to buy Xenon bulbs and not LED bulbs unless you fit a correct value resistor in series...
djtimyd
Colorado
I'm assuming you mean switch off / car off as well correct? If there is truly current bleed thru on the circuit that causes the off lights to actually be very dimly on, then hopefully it wouldn't do it while the car is off as well - otherwise that would drain the battery eventually when the car is parked.
My primary reason for wanting LED interior lights is because sometimes I am an idiot and I leave the dome light on overnight in my XJ. The current draw on the LED is so much less that when I come back out the next morning, my jeep will start no problem. With the standard incandescent bulbs, no such luck. 4 lights on for 8 hours and my jeep was dead. I hate the color temp of the LEDs (they now make warmer color temp ones, but when I bought mine, they were only available in 6000k daylight temp), but they have saved my bacon several times. I was hoping to do the same thing with my KJ but if there truly is a problem with them being not off while the car is running, that would be super annoying at night.
Aceofspades
Buffalo
Every time I did a LED swap - they glow. Cheap ones and ones from super bright led .com
Kinda like a mood light at night
