Clunking from rear, pics…
Biff
Hi guys. I’ve read everything regarding the clunking and just want to be sure my UCA is ok, pics included
I’d also like to know what’s missing at my transmission?
turblediesel
memberable
Alaska
A transfer case maybe? 2WD?
My "boomerang" hasn't gone bad so I don't know how they sound when they go. The rear lower control arms go bad and there's a recall on them so... free?
Biff
Yes 2wd, I just got the lowers replaced. I watched a couple videos on uca replacement and the ones they were replacing were really loose. I’m not sure what bad ones look like hence the pictures….. Thanks!
Biff
Pry up and down on the ball joint on your TRI LINK
If loose replace
Thanks Tom, they look good??…. Is Crown ok for replacement in the driveshaft rear seal?… it was supposed to be OEM mopar, should I return?
Biff
Thanks Tom!!… the UCA is done… Truly appreciate your guidance Sir!!
Done as in toast!!… looking for a Mopar
