Ball jointed sway bar links
ikuo78
Japan
To be freed from the restraints of the four rubber bushes,
I made the sway bar link into a ball joint,
and I extended the link to make the connection point of the sway bar rotation fulcrum and the sway bar link closer to horizontal.
I got an excellent ride.
seafish
Do you have a parts list for making that end link???
what is the grade of the steel used in the green turnbuckle?
ikuo78
Japan
I bought this at amzon.co.jp.
The screws are a little short, but
It's working fine so far.
It seems like similar general-purpose parts can be procured anywhere.
ikuo78
Japan
I'd say that stiffened it up a bit.
Later ZJ's came with something similar but the ball joints always go bad.
In situations where you only want one leg to move, such as when passing through a pothole at high speed or going over a step on the sidewalk on the side of the road, I get the impression that one leg is moving well.
There has certainly been a slight increase in feedback regarding the wheel track,
By the time you empty a full tank of gas, you won't be able to tell.
I get the impression that my feet have become softer overall.
I think this is because the load that twists and bends the four rubber pieces is gone.
Ball joints do make clicking noises when they deteriorate, so I'm concerned about their lifespan.
So far, I've been doing well for 3 months.
