NOW.................................
when you get the coilovers shoved up in place start the two inside bolts on
Then position the clevis to where it should be headed in the right direction
Using two ratchet straps , attach one on each leg, then to the other side and then easily pull them into place
This is another area where people spend too much time on a simple task
and yes, ......it really work , wink wink
Oh and make sure your brake hose in inside/behind the spindle before bolting the ball joint up
