ABS module rebuild
Raybird2112
I have a faulty abs control module on my 2006 Jeep Liberty Sport. The part is discontinued but I found a company who can rebuild them. Anyone done this before with success? Anyone have any other ideas?
Did you have a shop scan for stored ABS codes? If so what are the codes?
Just curious, how much to have module re-built?
My 2004 has no abs or traction control. I'm glad I kept it simple.
I'm not sure if this will help however here are some threads regarding the module etc.
LINK Below:
https://www.jeepkj.com/search/362702/?q=abs+control+module&o=relevance
Raybird2112
LINK Below:
Yes, I had a shop look at my Liberty. They traced it to a bad abs module. I found a company who is going to rebuild it for $400. All the abs lights were on my dash and it gave the c1020 code.
blackhawk
Venezuela
Regarding c1020 code it can refer to a bad rear wheel sensor. To check if all of they are apparently good you must check if all of them are sensed with scanner. If not, you must check if the 12 voltage is present in every connector, just to check if the harness is in good order
HeavyJohnny
Do you have a link to the shop that rebuilds them? Mine took a shit this week too.
