Jaber
Greetings,
So I took the Jeep to a shop to get some warranty work done. The main one getting the A/C system checked out.
The A/C Clutch will turn on for 3-5 seconds and then turn off for 5 seconds and turn back on for 3-5 seconds. It will continue this cycle.
The shop claimed the A/C Compressor was bad and found a leak. They fixed the leak, replaced the A/C Compressor and Receiver Drier.
It's been two days and the A/C clutch is still doing this. A/C seems to blow cold air, but tough to tell, since temps outside is 40-50F.
Is this normal, since it needs to cycle? Or does this mean the problem isn't technically fixed.
Thanks.
Thanks.
