3.7 timing chain longevity
MrMopar22
Charlotte, MI
My '02 has 165,000 on it and has never been apart. Do they have timing chain failures? Some engines go for ever on the timing chain and others have to have them changed religiously, I wasn't sure which one the 3.7 was.
I think your confusing timing chains and timing belts.
Timing belts have a change interval between 40k-100k depending on model and timing chains generally outlast the rest of the engine.
MrMopar22
Charlotte, MI
Not necessarily. The 2.7 has a chain and they love to break, especially if you do a lot of high RPM acceleration. Undone, the chain is about 4’ long. They stretch until the tensioner cannot keep them tight any more. Once they are loose, the slack allows the cams to jerk the chain as they turn. Then it's only a short time before they break. I've repaired dozens of them. It bends all the intake valves. I’ve has some as low as 80K and as high as 140K before they break; it all depends on how hard you drive. I didn’t know if 3.7 shared the same fate, I wanted to do some preventative maintenance.
J-Thompson
just south of doucheville
Never known of a 2.7 in a Jeep
Know of a 2.5 but I thought it had a chain
just like the 4.0 or 3.7 which as stated will
out last the engine
And don't be a dummy like me and ask
"I don't see any thing in the owners manual about
when to change the timing belt when I know I need to!"
Only to find out that your 2.0L car engine has a chain
I havn't heard of any 3.7L timing chains breaking on the forum anyway. There's 3 timing chains in the 3.7L and some on here have high mileage. Really, anything mechanical can break but I wouldn't worry about the timing chains. Just keep driving it.
Marlon_JB2
Kombat Edition Jeep
Harrison Township, MI
Timing chain break? On a 3.7L?
You'd break a valve spring before that happens.... about 10 times!
(Just putting this into perspective... timing chains on a 3.7L never break...)
