15x8" level 8 trackers
cplchris
Albany, NY
let me start by saying that I am aware that the general consensus is that a 15" aluminum wheel will not fit over the brake calipers on a kj. a while back a member on here (wulfhound) got these exact wheels and they fit fine on his KK. so from the looks of it they should fit on a KJ, unless the front brake calipers are different on a KK? here is a link to the wheels:
http://www.summitracing.com/parts/lev-63772/overview/
they are 15x8" with 3.32" backspacing and a -30mm offset
i have a 2006 KJ sport with the 2.5" bds lift, 1/4" top plate, 3/8" clevis, 2 extra upper isos in the rear, and jba 4.5 a-arms
before i pull the trigger on them i want to be sure that they will fit. thank you for your help in advance.
-chris
Hedsic
Des Moines, Iowa
I don't know if they will clear the caliper or not but I just wanted to say that is a mighty fine looking wheel.
CactusJacked
Chicago Suburbs
Discount tire sells those wheels for $99 each, free shipping, and a $50 online order savings.
Click link > Level 8 wheels for a crapload less.
As far as clearance, check their store to see if they have a wall sample that you can measure against. Nobody here can tell you for sure if it will clear unless they have that exact same wheel
Issue will be backspacing since it will sit the wheel / tire out more and could cause extra rubbing issues. Then you have the extra inch in width that adds to that. Just trying the wheel on with a tire on it and turning side to side will tell you nothing at all
Remember a 7 inch wide with 4 inches of backspacing works great, add another 1.6 inches out and..............
