fastcarsspeed
Ok so it is a 42RLE but what is the difference between 3 or 4 wire versions? I am noticing a difference in cost is the reason I am asking. Looks like the 4 wire is in more abundance and cheaper lol.
If the transfer case selector isn't working properly in the passenger compartment, you can always disconnect the cable from the lever on the t-case itself, then manually move it into neutral. that will disconnect the transmission and allow you to tow the vehicle in whatever manner you deem necessary. unless of course the t-case is also fubar'ed. then your best bet is to pull the rear driveshaft and tow it with the front wheels on a dolly.
