'03 Liberty - O2 Sensor wiring, help!
adamalsnayyan
Detroit, MI
So, I just swapped the dreaded 3.7L Powertech V6 (-_-) in my KJ after it threw a bearing. It's working great now. But I'm getting an O2 CEL code because when I was pulling the old motor, all four wires from the driver side upstream(before the cat) O2 sensor's wire harness came out, and I don't know their designated locations to replace them properly. The vehicle runs perfectly, but I would like to get rid of the CEL. So, I was wondering if anyone knew exactly which ports each of the wires go to or if anyone was willing to dig down in their engine bay to maybe help a guy out (naughty). This is the vehicle side harness(male harness). Here are some pictures to give a better idea of what I'm talking about.
Sorry for the out of focus pictures, I was in a hurry.
Thanks.
Hope this helps...
40795[/ATTACH]"]
danielrw90
Jackson michigan
Hey I am having similar problem only it's my oxygen sensor on drivers side just behind converter. If someone could give me a diagram or just tell me which wires coming from the car go to which wires on the oxygen sensor I would really appreciate it thanks.
mobiledui
ORLANDO
Help!!!
Thanks.
So, i have a p0151 code on this o2 sensor. IM like 90% sure its a wire chafing issue. I want to buy a new connector and cut and run wires to the o2 sensor but i cant seem to trace the wires to know which ones to cut at the top of the engine. I see in the picture that you posted the color of the wires after the connector which i couldnt see before, but even with that new information, i cant seem to find those color wires at the top of the motor or anywhere else for that matter. Where in this harness do i need to open up to be able to run new o2 wiring?
This is from the 2004 FSM re downstream.
