Finally diff in 3.7’s (well at least to 05)
Remember I only covered up to 05
Need an engine for your 02-03 well now here it is:
1. All bare blocks 02-05 are the same no change will fit both auto trannys.
2. All bare heads Left and right side are the same 02-05
3. All head gaskets, and timing chains and guides are the same
What’s not the same…..
1. Crankshaft same 02-03 changed in 04-05. this is what prevented
the 02-03 ****** from fitting on 04-05 3.7 engine
2. Came gears 02-03 are the same changed to electro magnetic wheel on
the 04-05
3. Crankshaft gear same 02-03 changed 04-05.
So now if you want a 04-05 engine in your 02-03 here is what you do…..
1. Strip off the 04-05 to a plain long block (no sensors, manifolds ect)
2. Purchase a 02-03 crankshaft kit comes with all new bearings about $280
3. Now replace the cam gears from the 02-03 on to the 04-05
4. Put in the crank kit. You can still use all the timing chains and guides
5. Now switch over all your manifolds Ex, In, Injec, all sensors
don’t forget to switch over the crank pos. sensor they are diff.
6. Install the engine.
the 04-05
