How To
HOW TO: Change your Power Steering fluid
This is a discussion on HOW TO: Change your Power Steering fluid within the How To forums, part of the Jeep Liberty - KJ (02 to 07) category!
Time Needed: 30-45 minutes Items Needed: Turkey Baster 2 quarts of Power Steering Fluid or ATF+4 (check your owner's manual) ...
Old 04-14-2007, 01:17 PM   #1 (permalink)
jeepkj02's Avatar
Default HOW TO: Change your Power Steering fluid
Items Needed:
  • Turkey Baster
  • 2 quarts of Power Steering Fluid or ATF+4 (check your owner's manual)
Steps:
  1. Remove power steering cap and remove as much fluid as you can with the turkey baster.
  2. Pour in new fluid into the power steering reservoir and screw cap back on and start engine. Turn the steering wheel lock-to-lock for a few minutes. (About 10-15 times) Do not stop between turns.
  3. Turn engine off.
  4. Repeat Step 2 and 3 until you finish the first quart. This is to get as much of the old fluid out.
  5. Finally, pour in your fluid one last time until it reaches the "hot" line on the power steering reservoir.
  6. Your finished. Repeat every 7,500-10,000 miles.
2002 Jeep KJ Sport 4x4
DOB: 5/17/01 ~ Mileage: 84,xxx
Current Mods:
OME MD Lift w/Ranchos, ARB Bumper, Firestone A/T on Cragars, Optima Red Top, Flowmaster Super 44, Hella 500's
jeepkj02 is offline   Reply With Quote
Old 04-18-2007, 07:45 PM   #2 (permalink)
richre1's Avatar
But That Doesnt Get All The Fluid Out?? What Bout The Rack
richre1 is offline   Reply With Quote
Old 04-19-2007, 02:35 AM   #3 (permalink)
tjkj2002's Avatar
That's why you turn the wheels from lock to lock for a few min,it circulates the fluid from the pump to the PS pump.
Old 05-20-2007, 03:01 PM   #4 (permalink)
My question is: How in the heck are you supposed to get the cap off? There is no way for mine to come off because it is trapped underneath part of the windshield cowl and a wiring loom. I can get to it enough to loosen it, but I can't get it off to access the fluid.
SavageUrge is offline   Reply With Quote
Old 05-20-2007, 04:10 PM   #5 (permalink)
jeepkj02's Avatar
I don't know if they changed anything post-2002, but mine is near the battery to the right of the serp belt. Care to post a pic? There was plenty of room to remove the cap and suck out/fill up the fluid.
Current Mods:
Old 05-20-2007, 04:11 PM   #6 (permalink)
Marlon_JB2's Avatar
Kombat Edition Jeep
It was the same on my 2004... and my sister's 2005.
Old 05-20-2007, 04:42 PM   #7 (permalink)
tjkj2002's Avatar
The PS pump is in the same place on al KJ's from '02-'07(CRD's not included).Do you know where your oil filter is? If yes then the PS pump is right above it,it has a white plastic resivoir and a yellow plastic cap.You must be trying to remove the tranny dipstick if it is by the firewall.If you don't know where your oil filter is you will see the PS pump just to the left and a little down from the battery,also a little under the upper radiator hose.If you don't know where the battery is or the upper radiator hose is take it to a shop cause you shouldn't be under the hood.This is only for gas KJ's.
Old 05-26-2007, 10:39 PM   #8 (permalink)
OK, thanks. I am quite familiar with the oil filter so I shouldn't have a problem locating it. As for what I was attempting to remove the cap on, it is located just underneath the wiper cowl in the far right corner of the engine compartment (if you're looking at it head on). What is this round reservoir? I'll try to get a pic of it if you can't find it. I have a manual tranny so I don't have a dipstick.
2003 Silver Renegade 4X4 5-Speed - NO ABS - Full OEM Skids - K&N FIPK II CAI - Garmin GPSMAP 76S
Xcelerator Free-Flow Muffler - Piaa 520 Ion Crystal Aux. Lights - Firestone Destination A/T's (235/75/R16)
Thule M.O.A.B. Roof Rack - Sirius Sportster 4 Satellite Radio - Flexi-Gutter Ram Air Thingy
Old 05-26-2007, 10:56 PM   #9 (permalink)
tjkj2002's Avatar
The only 2 reserviors next to the firewall is the coolant overflow(left side) and the brake master cylinder(right side),since you have a manual then you will also have the clutch master clinder on the right side,that must be what you are trying to open.
Old 01-08-2008, 02:48 PM   #10 (permalink)
AlexKJ's Avatar
Exclamation Related TSB
Steering - Power Steering Fluid Usage
NUMBER: 19-005-03
GROUP: Steering
DATE: Aug. 29, 2003
THIS BULLETIN SUPERSEDES SERVICE BULLETIN 19-007-01, DATED AUG. 2, 2001, WHICH SHOULD BE REMOVED FROM YOUR FILES. THIS IS A COMPLETE REVISION AND NO ASTERISKS HAVE BEEN USED TO HIGHLIGHT REVISIONS.
SUBJECT:
MODELS:
1993 - 2003 (AB) Ram Van
1994 - 2004 (AN) Dakota
1994 - 2002 (BR/BE) Ram Pickup
2004 (CS) Pacifica
1998-2004 (DN) Durango
2002 - 2004 (DR) Ram Pickup
1996 - 2000 (GS) Chrysler Voyager (International Markets)
1995 - 2000 (JA) Cirrus/Stratus/Breeze
2001 - 2004 (JR) Sebring Sedan, Stratus Sedan1 Sebring Convertible
1996 - 2000 (JX) Sebring Convertible
2002 - 2004 (KJ) Liberty
2002 - 2004 (KJ) Cherokee (International Markets)
1993 - 2004 (LH) Concorde/Intrepid/Vision/LHS/New Yorker/300M
1996 - 2000 (NS) Town & Country/Voyager/Caravan
2002 (PG) Chrysler PT Cruiser (International Markets)
1995-2004 (PL) Neon
1997 - 2003 (PR) Prowler
2002 - 2004 (PT) Chrysler PT Cruiser
2001 - 2004 (RG) Chrysler Voyager (International Markets)
2001 - 2004 (RS) Town & Country/Caravan/Voyager
1993 - 2002 (SR) Viper/Viper Coupe
2001 - 2004 (ST) Sebring Coupe/Stratus Coupe
1997 - 2004 (TJ) Wrangler
2003 - 2004 (VA) Sprinter
1999 - 2004 (WG) Grand Cherokee (International Markets)
1999-2004 (WJ) Grand Cherokee
2003 - 2004 (ZB) Viper
2004 (ZH) Crossfire
DISCUSSION:
The factory fill power steering fluid for most 2004 model year Chrysler Group vehicles is ATF+4 (MS9602) and it provides superior performance at both low and high temperatures. WJ/WG and ZH vehicles use unique power steering fluids. Refer to the table to identify factory fill and the approved service power steering fluid by year and model. Note that MS9602 is Red in color and MS5931 and MS9933 are Amber/Yellow in color. All three fluids will darken in color with usage and fluid color is no longer an indication of fluid condition.
The part numbers for MS9602 are 05013457AA (quart) and 05013458AA (gallon). The part number for MS5931 is 04883077 (quart). The part number for MB345 is 05127381AA.
MS9602 should not be mixed or used as a "topping off" fluid on systems requiring MS5931. On some past models, MS9602 should be used as the replacement fluid. On these models, if a power steering system is being serviced that results in a large fluid loss, such as a pump, hose or gear/rack replacement, the complete system should be drained and filled with MS9602.
NOTE :This bulletin supersedes owner's and service manuals for the vehicles listed above that may state to use MS9933 in the power steering system, and that may state not to use automatic transmission fluid in the power steering system.
AlexKJ http://www.jeepliberty.es
Jeep KJ 3.7L (Cherokee) '03 4x4 Limited Edition / Light Khaki Met. / Light Taupe Leather / 42RLE+SK604 / NP242 Select-Trac / 4 discs ABS / Export Equip. Group / Convenience Group I / Off-Road Group / Power Sunroof
Mods: Lift 3.5'', 31'' MT on Moabs, R&P 4.10:1, ARB RD93 & RD100, Renegade roof lights, 02' rad + '03 aux trans cooler, custom trans skid, rock rails, RedTop, VHF, BT, OBA, EVIC + TPMS + Homelink
AlexKJ is offline   Reply With Quote
