-First things first you will need your new axle. Napa is your best bet. good axles with a lifetime warranty. The core charge on the axle is pretty hefty but you will get your money back later
-Second you will need a axle nut socket. I wouldnt spend any money on one unless your really really rough on the trails and plan on breaking some axles. Autozone has a loan a tool program where you pay for the tool but get all your money back. They dont have a 35mm like you need but they do have a 36mm and that works perfectly.
-Now time to get dirty, With the tires on the ground loosen the axle nut and lugnuts, i think on stock rims you have to loosen it with the tire off. Then hit the end of the axle with a big hammer once just to get it loosened up
-Jack up the front of the jeep and use a jackstand to secure the side your working on, and remove the tire.
-Remove the lower strut bolt and sway bar endlinks and then remove the clevis from the strut
-Remove ball joint nuts and pop the ball joint out of the hub. I used a strap to secure the hub from falling and messing up the brake line. Made the whole job a lot easier.
(remove everything that is marked in blue)
-Insert a pry bar between the transmission and the CV axle it will pop out pretty easy. Try to be easy on the axle seal and pull the axle straight out and not at an angle.
-Once the old one is out you can toss the new one right in its place.
-Put the axle through the hub with the axle nut finger tight to hold it in.
-Put the ball joints, sway bar link, and strut bolt back together.
-Put your wheel and lug nuts on, lower the jeep and tighten the lugnuts and axle nut. (stock rims may have to tighten axle nut while wheel is off)
-Return the old axle for your core money, and return the socket for that money back.
-Enjoy your new axle with lifetime warranty and its non greasy goodness!!!
