How To
HD fan shroud mod for quick removal
This is a discussion on HD fan shroud mod for quick removal within the How To forums, part of the Jeep Liberty - KJ (02 to 07) category!
credit here goes to uss2defiant for the info on how to do this, just providing more info here on how ...
Like Tree7Likes
  • 3 Post By jeeptorino68
  • 2 Post By turblediesel
  • 1 Post By uss2defiant
  • 1 Post By gillt
Old 04-25-2016, 12:35 AM   #1 (permalink)
jeeptorino68's Avatar
Default HD fan shroud mod for quick removal
credit here goes to uss2defiant for the info on how to do this, just providing more info here on how to do it.
this is a MUST if you have the heavy duty cooling system (if you ask me) the heavy duty cooling has the electric fan and a huge shroud with a clutch fan.
the shroud cannot be removed until the clutch fan is loose, which is hard to do with the shroud there...
first remove the fan shroud (and clutch fan).
your shroud will look like this:
cut off about half and inch of material from the bottom lip of the shroud where the taper stops. i drilled a hole at each corner and used a jig saw and reciprocating saw to do it.
end result:
now the shroud can be removed with the clutch fan installed. just half and inch of material is all it takes!
TwoBobsKJ, uss2defiant and gillt like this.
Kyle
02 KJ Limited, 255 70 16 General AT2, Ironman Lift, JCR sliders, Mopar skids, radiator skid, LS/4.10 gearing, factory front hooks and rear hitch
92 XJ 4.0 HO,AW4, NP242, 31s, 1.75 spacer and ZJ V8 coils, double cherokee leaf pack and 2 inch rough country shackles, 2.5 inch dnynomax exhaust, magnaflow cat, front hooks & rear hitch, gas tank skid, front skid, warn t-case skid, 99+ intake, bored TB
jeeptorino68 is offline   Reply With Quote
Old 04-25-2016, 12:48 AM   #2 (permalink)
turblediesel's Avatar
Same idea as the CRD. I kept the lower section for our iceberg puddle refreezing break-up season. Serpentine iceberg encounters can only be bad.
Ahhh, I now see you get to keep some shield on the bottom. Cool!
TwoBobsKJ and gillt like this.
Last edited by turblediesel; 04-25-2016 at 12:50 AM. Reason: second picture showed up
turblediesel is offline   Reply With Quote
Old 04-25-2016, 01:00 AM   #3 (permalink)
uss2defiant's Avatar
Send a message via ICQ to uss2defiant Send a message via MSN to uss2defiant Send a message via Skype™ to uss2defiant
i think the tricky part is getting the right sequence of the sides to pass the tranny cooler lines and the upper radiator hose.
TwoBobsKJ likes this.
2003 Jeep Liberty limited 3.7L V6 4x4 w/ tow package.
All stock. Yokohama Geolandar A/T-s 235/65R17 108H
45RFE, NP242, Selec-trac, Trac-Lok rear diff., ABS
~170k Miles
My KJ youtube playlist for ref. https://tinyurl.com/jeepkj
uss2defiant is offline   Reply With Quote
Old 04-25-2016, 11:51 AM   #4 (permalink)
Definitely is, once you wiggle it a few times back and forth it clears past those though
Old 07-08-2018, 03:14 PM   #5 (permalink)
I had to do the same thing. A lot easier to get it out of the way know.
jeeptorino68 likes this.
gillt is offline   Reply With Quote
