2003 Liberty - noticed fluid at the outside bottom of the reservoir, and looks very much like it's coming from between the pump and reservoir. Cleaned it off and Im going to see if I can tell exactly where the fluid is coming from, because it drips a bit onto the high pressure line and that is wet also. Previous owner had high pressure line and oem pump replaced with this A1 Cardone.
Ive never had much luck with A1 Cardone products. Are these pumps prone to leaks between the reservoir and pump? Thanks.
