andylarry
Hello everyone.
I am trying to help my farmer fix his 2004 Liberty sport. There is no signal / pulse to the #6 ignition coil or fuel injector. This happened after a leak from the coolant reservoir got that area wet, and kept it wet, for quite a while. Can anyone supply me with a wiring diagram, or better yet, the exact wires that I need to find, to check continuity from the injector and coil plugs back to the PCM plugs? There are 4 large plugs on the PCM. I'm guessing that the wetness from the leak could have possibly damaged the PCM. Of course, it would be best to make sure that the wires have proper continuity before I attempt to replace the PCM.
Thanks for helping!
Andy
Thanks for helping!
Andy
