arielflash
Hi,
Ever since i got my libby there is a pretty loud humming sound when as speed goes up - some people say it sounds like a bad bearing (which one??)...
Already replaced tires, both front hub assemblies, passenger side CV, front and rear driveshafts reman... whats the next thing i should check ?
Also, theres a noticeable "rumbling" noise sounds like coming from front starting at ~25-30 mph... sounds like its coming right behind the dashboard but I couldn't see any loose parts inside when taking the radio off and having a look... any thoughts ??
I can also feel some vibrations going ~50+ mph (event after having both rear & front shafts remanned) - not sure if its related to any of the other noises...
Isn't there a proper way to locate where exactly noises are coming from? :\
Thanks !
Thanks !
