09-04-2012, 02:40 PM
#4 (permalink)
How do you know that 4HI (full time i assume) and part time don't work while 4LO does? I was having problems with my transfer case also. It would pop out of 4wd and into 2wd, mostly when stressed in 4LO but also in any 4WD mode. I could still run in "2LO" (front wheels wouldnt engage) or full time or part time just without front wheel power. I swapped out the transfer case because i found one cheap and needed a DD. When I take it apart I suspect I will find either a loose chain, worn teeth on a sprocket, or bent shift forks. I have the np242 select trac, not the np231.
2004 limited, ARB Bullbar, ome/bilsteins lift with top plate and 3 ring clevis, Engo 10000lb winch, U joint front driveshaft, LT 265/70s, Pink booster seat, Hella 700 lights up front, Rear Aussie locker, cb radio w/ 102" whip, gas tank and tc skids, custom cross bars, relocated washer bottle, jba ucas
