Removing the Glove Box
2003KJ
Planet Earth
I need to remove my glove hole (I mean box). At my part time job, it requires that I have a pen and a sticky pad (post-it note pad) on me at all times. Well when I leave that job I just throw them in the glove box and go. I've lost 3 pens and an ENTIRE sticky pad to the "monster" behind the box. The area between the top of the box and the bottom of the dash is too narrow for me to get my not skinny hands in, so where are the screws (or bolts, whatever holds them in) located to get them off?
Thanks to all.
chefdab
glove box
I had to remove mine to do my cb install. To remove it: open as far as normal, then slide to left and pull down to disconnect the rest of the way. It just pops out. reverse the process to install. Make sure it's empty first or you'll dump everything on the floor in the procees.
Tokyojoe1965
Denver Metro, CO
Toss your pens and Post-its in your center console...or where the ashtray would've been, unless you have an ashtray there.
2003KJ
Planet Earth
center console has CD's and my tire pressure guage. The area of where the ash try is on the older models is being occupied by a hands free head set with speaker and car mount for my company Cell Phone. The holder got 3M'd to the dash and the speaker and wires are bunched up under the heater controls
valvestem
Northeast US
Box
From the FSM CD
GLOVE BOX
REMOVAL
WARNING: ON VEHICLES EQUIPPED WITH AIRBAGS,
DISABLE THE AIRBAG SYSTEM BEFORE
ATTEMPTING ANY STEERING WHEEL, STEERING
COLUMN, SEAT BELT TENSIONER, OR INSTRUMENT
PANEL COMPONENT DIAGNOSIS OR SERVICE.
DISCONNECT AND ISOLATE THE BATTERY
NEGATIVE (GROUND) CABLE, THEN WAIT TWO
MINUTES FOR THE AIRBAG SYSTEM CAPACITOR
TO DISCHARGE BEFORE PERFORMING FURTHER
DIAGNOSIS OR SERVICE. THIS IS THE ONLY SURE
WAY TO DISABLE THE AIRBAG SYSTEM. FAILURE
TO TAKE THE PROPER PRECAUTIONS COULD
RESULT IN ACCIDENTAL AIRBAG DEPLOYMENT
AND POSSIBLE PERSONAL INJURY.
(1) Open the glove box.
(2) Squeeze the stop tabs located on the sides of
the box and allow the box to open fully.
(3) With box in the full down position slide the box
to the right off of the hinges and remove.
INSTALLATION
(1) Position the box on and slide the box to the left
to engage the hinges.
(2) Close the glove box.
2003KJ
Planet Earth
Sounds easy enough.
Thanks for the info valvestem.
I'll still find a way to screw it up, watch...LOL!
I don't really see why i would have to disconnect my battery just to remove the box. No lights in there or anything. Or is that just what they recommend when you do anything to a vehicle?
Now watch, my luck, the passanger air bag will blow up in my face right as I get the box off. Kinda something that would happen on the Simpsons (for those who watch that show)
yoda13
Texas
When I work on the vehicle, I am just clumsy enough to cause the airbag to pop out, I would disconnect the neg. battery cable as well..... :-k
