AFT2008KK
- Joined
- Nov 27, 2022
- Messages
- 68
- Reaction score
- 52
Shoot. Maybe the wiring on the TCM side is loose or pinched? I don’t know what the TCM looks like, so I got out my parts manual. It is #2 in this schematic.
I wouldn’t put much stock in the TCM location on the schematic since the TIPM is drawn on the wrong side, LOL.
You must be registered for see images attachMounted on passengerside inner wheel well. Pic below of Dorman Reman. Not sure about reman or pull a part unit.
I have the same Jeep. Started having problems with rough start. Guess what. Replaced battery in key and all is just fine. The TIPS system needs to get the ok from the key I guess. Good luck.Latest update. And hopefully the gods of the KK universe will have insight.
Yesterday died in driveway. Wouldn’t restart. Today for r/o efforts i put in old tipm. No go. Starter would crank but no start, and front windows were inoperable and no power at the obd2 port.
So i put back new TIPM. A/c works intermittently and it runs good for 10 minutes and stalls. Windows work and obd2 has power.
Ill get to a shop for a real scanner to see whats there. My generic scanner reveals nothing.
Could it be the ECM or TCM (depends who you ask what it is called)?
Thoughts. Advice. Sacrifices possible if needed.
The button battery in the head of the key?I have the same Jeep. Started having problems with rough start. Guess what. Replaced battery in key and all is just fine. The TIPS system needs to get the ok from the key I guess. Good luck.
Yes. That’s the one.The button battery in the head of the key?
my 08 did the same thing! It was just a warning shot for what was coming! about a week later it just died on my way home. turns out my 2 month old alternator gave up the ghost! Just goes to prove new ones go bad too! i would have it tested.Hi All. Advice needed to avoid chasing my tail in circles. 2008 Kk limited 128k became posessed a few days back.
While driving around town, wipers on / off automatically, dash lights flashing on/off like Xmas tree, tach and speedo drop to zero and then kick back on, and radio kicks on & off all while driving.
Now running fine. No gremlins present
Alternator was replaced a week prior. Battery (interstate) installed 1/2023. Aftermarket radio w/ canbus adapter installed 1/2023.
Pulled codes. See pics. Codes cleared, and ill see what returns. FYI no check engine light on.
Any thoughts or tips / tricks? A faulty BCM or does TIPM need refurbishing?
Thanks in advance.
