Lift kit
Robert Vanni
Hey yall
I just bought me a 2002 liberty having trouble finding a lift kit can anyone help me out? I do not want just spacers
Spr
OME 927 Front springs
OME 948 Rear springs
Bilstein 24139168 Front shock (same as stock)
Bilstein 24-185660 Rear shocks (Can also go with rear bilstein shocks from 99-04 dakota crew cab)
2 hockey pucks per side mounted in lower spring perch and drilled in the center
Mount these pucks with 3/8 inch bolt, 2 1/4 inch long with lock washer and nut
You could also use conduit nuts to help level the jeep.
Hey yall
Lift kits are the exact same from 2002-2007
The above list is almost right on and works well, have lifted over 60 with the above springs and shocks
also need teraflex bumpstops for the front use them in place of the stock ones
also it will sit level with the above setup so no need for the conduit nuts that are mentioned
will be sitting 2.5 inches above new stock height
Rear springs are 948 NOT 947
PLUS we have a whole section just about lifting a KJ
Robert Vanni
So I should go by the above list and do not order a sky jackets kit?
Spr
Thanks for catching those 2 things Tom. Accidentally fat-fingered 7 rather than 8.
Robert, you'll want to go with the OME stuff. Tom has mentioned many times across this forum about the Skyjacker, BDS, and any non-Old Man Emu lift kit since the spring rates are similar to stock and they sag quickly.
For reference, I'm currently in the dilemma of needing to replace my shocks, springs, and rear upper tri-link (mine are stock) and my mechanic suggested Quick-strut assemblies (We have coilover shocks... damn marketing).
I will not go with the assemblies since they will sag and my KJ already rides really rough so I'll go with OME.
You could go with the Skyjacker but it will ride rougher and wear out faster than going OME.
Robert Vanni
Also anyone here from Jersey and want to do/ill help with the work. I am an electrician not so much a mechanic
Robert Vanni
Skyjacker springs are weak , same as stock and will sag down in short order , so yes DO NOT BUY
Hey Tom I finally tracked down all the parts you guys suggested. Wondering what is a good tired size to go with. Is 33×12.50r15 a good size to go without much trimming needed?
LOL, 33s you need 4.5-5 inches of lift at least plus a regear to 4.56s which you can not do anymore
for a 2.5 inch lift and stock width wheels 245-75-16s
will lose some power and mileage due to lower gears would be better
plus will have to pound over the pinch weld
