front and rear axle oil changes
Foutrack
Hello everyone,
For the front and rear axle oil changes I again have 2 opinions, the addition of an MS-10111 type additive is only on the rear? or both?
Thanks in advance
duderz7
Weiser, ID
Rear only, and only needed if you have a trac-lok. You'll be able to tell once you've removed the diff cover, just look for pictures on the interwebs. I also suggest a lube locker gasket.
