Driver’s side running lights not working on 07 KJ keep blowing fuse where to find the short?
Shaneomac
I have 07 KJ just purchased and the drivers side running lights are not working front or back replaced fuse and blows again. Anyone have a fix to find the short
jeepman1946
IF you have a trailer tow set up, check that first. If there is corrosion or debri there it could be causing a short. If that doesn't fix it, pull the bulbs out and examine them. I had one go bad and short out the fuse.
Hope that does it. If not, you will be digging into chassis wiring.
mike808
San Diego
Did you ever resolve this issue? I have the same issue on my 03 renegade. No position lights on the driver's side and no turn signals. But all other lights work. I've changed all the bulbs and even the actual taillight assemblies along with the rear upper brake light. No trailer hitch installed (awaiting dealer parts so they can install, never had one).
Jeremy-WI
Home
Check the wires going to the license plate light, it might be shorted
I recently had it where my trailer adapter took a carp, and it was blowing the fuse for the driver's side.
  • Like
Reactions: JRB
