77 Ford FW axles
Rescu2000
Huntingdon, TN
How would these work for a SFA swap?
77 model dana44 3.73 gear ,77 model 9 inch 3.73
Not sure what they are out of. I am going to ask...
J-Thompson
just south of doucheville
probably work out fine
If I had to guess I would say Bronco or 1/2 ton p/u
3.73's are pointless
you will need to regear
I think that both of those carriers will go to 4.88 maybe 5.13
the one I am not sure of is the 9"
Rock Lizard
Colorado Springs
Deepest gearing I have seen for the 9" is 7:33 gears, which might be a little overboard for an SFA setup unless you are running 52" LTB's. 5:13's will work great for 35's as a daily driver and rock crawling. And that 77 HP44/9" combo will be a great swap, infact it is the same setup Ted (USAFCOP) has sitting here ready to go into his KJ.
incommando
SW Ohio
That is a great axle set for a 1/2 ton. For those looking for a set like it, I think '77 is as new as you can go without a ton of work. The newer ones have suspension mounts cast into the housing and are a bear to do anything with.
