drfd74
I'm having issues with my 07 KJ's washer bottle leaking at the pump base location. Ever since I had to drain the tank to put a better fluid that wouldn't freeze up. I removed one of the lines to the pump to drain it & must have broke the seal from the factory or something. I pulled out the pump checked the seal & looked alright so used some silicone sealer & worked for a while but now leaking again after I topped it off after checking my oil.
Now this time after draining again I pulled out the pump & cleaned off old sealer and checked seal/pump/ & bottle for any cracks & all good. This time I used some black silicone windshield sealer that I had, let it sit over night and refilled in a.m. w/ cheepie blue -20' stuff I used earlier and so far so good. BUT.........what a PITA.
Now what I need to know, is it just me or have any of you had a same problem?
Appreciate any comments.
drfd74
drfd74
