will they fit
Cardhu
Great White North
Theres a few unknowns.
I think the ford has a smaller hub size, 70.3 vs 71.5 so thats a no go if the hubs are not large enough. might need to be machined. People do put moabs on the ranger since the moabs have a larger hub.
The remaining issue is does it clear the brakes. It has potential to fit as the offset is less then stock. Won't know till you try.
Rim size aside, are you lifted? Are you trying to fit 31 10.5 15's? If the answer is no real lift then that part won't fit either.
