LFX1
Started the process of replacing the oil pan gasket. I had a pretty good oil leak and it was either that gasket or the rear main seal. When it came time to remove that structural collar between the engine and the transmission, it was bone dry on the inside facing the trans and the trans flex plate was also dry so I'm very hopeful all the oil was coming from the pan gasket. Fingers crossed.
Lotta work and I won't be able to start reassembling for a week. I have parts on order and the weather gonna get stormy for the next couple of days. Since I'm there, I'm also replacing the axle seals and lower ball joints (one was leaking). I'm putting a new pan on because the gasket was glued to the old one and it was difficult to remove. I may have bent it and I'm not gonna take a chance with it.
Here's some parts
Yay for YouTube University and you guys.
YOu going those better bushings on the diff? Doing steering bushings at same time? Mine needs done, dreading doing it. So let me ask this, is there any issues pulling both axles out, I remember one car I had when you went to change the cv axles you couldn't pull both out or the internals would move or something weird. Over all doing this how long did you take doing it? I will be doing this soon probably if I can wait till spring I may as I have other stuff going on, and I got to get the wiring back together this week. How do your axles feel they ever been replaced?
Quick question: I’m going to have the front differential out soon, and wondered if I should be replacing the engine mounts while it’s out. The Jeep has 240k miles. How expensive and difficult is that job?
eric1514
ID, USA
I was surprised at how good the bushings on the brackets that hold the diff in place looked so no, I won't be replacing those. The bushings on the strut clevises attached to the lower control arms are pretty beat and I might, at a later date, press those out in place rather that replace the entire control arm.
I'm going by this video in particular LINK and he removed both axles at the same time so I did, too. Doesn't seem to be an issue. While the front diff is sitting on a bench, I'm going to R & R the axle seals.
To get to the point I'm at right now, axles out, diff out, pan off, everything cleaned and ready to reinstall took me and my wife about 6 hours. I'm not a mechanic but I'm OK with tools and I own a bunch. I've never released the tapered part of a ball joint until this job so I go very slowly. The drivers side one took about 45 min. The passenger one took 5 because I knew how the second time. Getting the pan out took another 45 minutes because someone had RTVed the gasket to the pan and as you know, the gasket is bolted on to the block. Not fun. I'm replacing the pan because I might have bent it here and there shoving a putty knife in between it and the gasket to break the grip of the RTV. Knowing what I know now, I could probably do this disassembly in about 2.5 hrs.
The assembly should take me about 2-3 hours. Everything is clean and I know what to expect going forward.
eric1514
ID, USA
If you need to replace the mounts, I would think doing it while the front diff is out would be helpful. The view is definitely clearer. Sorry I don't know more than that.
Thanks! It’s just that I know it’s never been done before on my Jeep. I will see how bad the engine mounts look if I have a clear view of them. With the diff out.
burntkat
I am very.intimately familiar with the reason not to remove both shafts at the same time... Circa early 90s, helped a friend replace the shafts on his Maxima. Removed the second and heard CLINK from inside the transmission... The sound of the diff dropping out of position. That was a $2000 lesson....
burntkat
Not terribly expensive... But be aware the no-name brands aren't worth the effort to use. I put Anchor brand in a year ago, after replacing with no-name brand the previous year. They were completely thrashed in that time.
By Friday I should have everything I need to regear the front differential. I have a Yukon ring & pinion, axle bearings and seals, tools from Harbor Freight, and a R&P install kit is arriving Friday. If the weather cooperates this weekend, I’ll drop the diff and work on it. It will be my first regear, so I will be slow and methodical. I don’t have gears and an install kit for the rear differential yet, so I will leave the front driveshaft out in the meantime.
DeVilliers
Hi,
I did mine a few years back. 2005 KJ. Propped up the engine with a jack to take the weight. Removed the one side and installed, then the other side. It's a pain, but doable.
burntkat
Is the front master kit still going for roughly 800 bucks?
It can, depending on where you get it. But I found a front master overhaul kit by USA Standard Gear (Yukon’s budget friendly line) with Koyo/Timken bearings for $140 which is essentially a steal.
The KK front diff uses the same gear sets and bearings as the JK Wrangler non-Rubicon Dana 30, so I’m sure it is way less expensive and easier to find than the KJ Dana Super 30.
I’m trying to piece this regear together on the cheap, with NOS gears from FB Marketplace and eBay (understanding there is some risk there in being ripped off). So far so good. I’d like to find all Yukon stuff but I am willing to mix and match to keep it reasonably affordable. I’m not purchasing any used gears, nor any unbranded or low quality stuff. I’d like to only have to do this job once for each axle, LOL.
LFX1
Finally got the Jeep back to running. So far so good it was the one wire on the ASD that corroded off, it was a pain to try to get it in there, but I managed to work it out. started up first try. This was challenge to narrow down, as all errors pointed you in different directions. Perseverance paid off.
Way to go. Congrats on getting it running again. Broken or pinched wires take so long to finally pin down.
Another question. I am planning on doing the axle seals and bearings for the front differential, as well as the regear, with the diff out of the Jeep. What is the best way to secure it to your workbench? Did you need to build a jig to hold it in position? I have a small vise but it may not be up to the task.
eric1514
ID, USA
I only did the seals.
I had my wife hold the diff steady while it was on my portable workbench. Removing the passenger side seal was a bit tricky. I deformed enough of the metal on the inside bore of the seal until I had a section that was large enough to grab with a pair of vice grip pliers. I have a slide hammer with a 90-degree bent hook on the end that I could use to stick into the joint of the pliers. A couple of good whacks and out she came. The real trick was to have my wife hold the diff steady. I was wasting my time beating on the slide hammer without the diff being secure. The driver's side was easy.
I'm wondering if leaving the diff in the car wouldn't be easier as far regearing. I would work on the rear without removing it. Wouldn't the front be the same?
Thanks for the info on replacing the seals. Sounds like it could be tricky!
With the location of the front diff in the car, up and behind the steering rack and the radiator support, I think it would be really hard to get the cover off and work on it there. One of the mounting structures for the diff attaches in front of the diff cover. My local 4x4 shop removes IFS front diffs to regear them so I just assumed I would be doing it that way too.
duderz7
Weiser, ID
The front needs to come out for sure
but look at all the room it gives to do engine mounts and rack bushings!
