burntkat
(quote)
and while you're pushing through said grease, you're also stressing the tension on the female connector side. oh and dielectric grease turns into sludge after a couple of years
(/quote)
This is REALLY a stretch... Given-
1- the grease is not at all what you'd call thick, as greases go....
And.....
2 - it's, you know, GREASE. So it's lubricative... And will actually ease the assembly pressure.
Also, we aren't assembling/disassembling this often.
I haven't seen a Dielectric grease decompose into sludge. Surely if it's exposed to dust it will soak it up, but that's not an issue on the outside of the connector. Yes it will get dirty but it won't affect the conductivity.
Nope. I'll stick with common practices in the work I've been doing for near 4 decades. Y"all so as you like, hut this is just a bunch of F.U.D.
burntkat
I changed the ATF over the weekend by removing the pan,
and today I found a clean magnet stuck to the fender of my bike.
How on earth did you manage this? ;)
burntkat
I towed my old Cherokee two hours home on a tow dolly years ago. I know it’ll handle it.
Out of curiosity, what motor and transmission do you have in the liberty. The CRD diesel AT is rated at 5k....but the 6bspd will derate that, as will the non diesel.
You CAN tow heavier.... But you are pushing your luck.
LFX1
Still waiting today for Amazon to bring some parts so I can soldier my wires up, needed new heat gun, and shrink wraps. Hopefully tomorrow if I don't work late I'll get it done.
seafish
So contact cleaner, but is there any other spray we can use to protected it from any moisture?
Dielectric grease at every connection is the best for keeping contacts dry and clean.
WD40 does a great job of driving out moisture and can be applied much more easily .. in fact, IMO driving out moisture from electrical panels is about the only thing WD40 is good for. ;)
Same as me. The 6 speed is the issue.
yea we ignore the "issue" part. :D
euro diesels of these things are rated 7500# tow capacity. same chassis. same rear end. same suspension. same brakes.
I came in at 10,060# gross one time. Granted I won't do THAT again by conscious choice (it did it, not fast, but you definitely had to plan your hills. and I had EBC Yellow Stuff brakes all around, so extra stopping power) but it *can* do it and you can do it safely.
The tow package on a Liberty is essentially just adding a mechanical fan clutch and fan to the front of the water pump. This auxiliary fan will help keep things cool when temperatures rise faster than the electric fan can handle. It works well and kicks in on long hills when towing my trailer. I’ve also added an aux transmission cooler to the front of the radiator and an aluminum PML transmission pan with fins and additional ATF capacity to help keep things cool.
LFX1
Took the Jeep camping last weekend - good times chilling in front of the fire eating and drinking :)
Looks deep off that bridge...
eric1514
ID, USA
This is just weird and creepy.
So I'm taking apart the front end of my Jeep to put a new pan gasket on. During the process, I notice the driver's side lower ball joint boot is leaking. I find the replacement on Rock Auto and order two. I need the removal/installation tool, too so I start researching. I start a thread here, I ask ChatGPT, I look at what Harbor Freight has and I finally look on Amazon and I ask a couple of question there. Turns out it's not as straight forward as I had hoped so I don't buy anything yet. I figure I'll start researching some more the next day.
Later that evening (last night), I'm streaming some TV in the background while reading a book and a commercial for a ball joint press comes on. Who turned me in? Rock Auto, Amazon? Both? This forum? One of the reasons I drive old cars like this Liberty is because I don't want a car that connects to the internet and spies on me, telling whoever where I am, when I buy gas, how fast I drive, etc. That's how naive I am. Turns out something as innocuous as repairing an old car in your driveway is enough to alert them as to what you're up to.
LFX1
So Trying to get my jeep wired up, but appears all the connectors I found, don't have the same back to lock in, anyone find these or use one that will lock in. 07 Jeep Lib. Under hood fuse box. Doesn't seem to lock in. Any ideas.
derekj
Powell River, BC
I went and grabbed a fuse box from a wrecked Jeep a few years back so I could have all the correct wiring ends. I used them to add some accy wiring into the fuse box to keep it looking stock under the hood.
LFX1
That is so crazy you posted this last night I seen a video where a guy was doing the exact same thing and it was an older video, but he was working on a Cherokee.
eric1514
ID, USA
Started the process of replacing the oil pan gasket. I had a pretty good oil leak and it was either that gasket or the rear main seal. When it came time to remove that structural collar between the engine and the transmission, it was bone dry on the inside facing the trans and the trans flex plate was also dry so I'm very hopeful all the oil was coming from the pan gasket. Fingers crossed.
Lotta work and I won't be able to start reassembling for a week. I have parts on order and the weather gonna get stormy for the next couple of days. Since I'm there, I'm also replacing the axle seals and lower ball joints (one was leaking). I'm putting a new pan on because the gasket was glued to the old one and it was difficult to remove. I may have bent it and I'm not gonna take a chance with it.
Here's some parts
Yay for YouTube University and you guys.
