LFX1
Got frustrated with the jeep today, went out to take a drive on a nice, day, crank no start pulled these codes trying to figure out the best place to start.
P0688 ASD/Main Sense Circuit
P2112 Electronic throttle control system unable to open bank 1.
I swapped the ASD Relay, I thought that failed about a year ago, and grabbed some and no luck with relay swap. All fuses look fine and I don't see any frayed wires. Couple reports on throttle body failure, and one seen both these together.
eric1514
ID, USA
It wasn't today, but I changed my own front dif gear oil and motor oil.
That's great. Really good DIY maintenance things to do. In the future, if you ever need to do any other maintenance or repairs and you're unsure on how, check out this guy's YouTube channel and his playlist for 2002-2007 Jeep Liberties. I'm promoting his content because he's a valuable resource for us owners of older KJs and KKs.
LINK
He's got about 50+ videos now and he does some pretty complicated repairs on his back in the garage without a lift, like most of us are going to have to do.
burntkat
No-start this morning. No turnover, no click, nada, just DEAD. Jumped it with my battery backup, went to work. Had to run all over hell and half of Georgia for a woman that didn't know how to take fingerprints to take mine. (don't get me started). Jeep runs fine at speed, sometimes want to die when I'm in neutral at a stoplight. Went to auto zone to have the battery and alternator tested. The stupid little girl there literally hooked the machine up BACKWARDS, pronouncing rhe battery is fine. Told her (rather impolitely) to get away from my vehicle and came home. Used my tester....
Battery is a Walmart Everstart Max, 34 series. Bought June of 2024. Should be 2/3 of the way through the warranty....
Alternator appears to be fine as well. Thoughts? I am fortunate this is a MT so I can bump start if needed....
EDIT - Ran around town a bit more with more of the same as above. Was able to start as normal a few times when it died at a light. Got home and was literally 5 feet from parking... Died. Would not start - no click, no lights, nothing, as my son was walking into the house (having literally arrived like 30 seconds before I did). We got the meter out, the battery tester, etc... Ran another test. Showing 12.6vdc at rest this time - fine. Test failed, indicating 'surface charge detected, turn on headlights.' Yeah, thst didn't happen - switched them on, no lights, nothing. So it appears the battery has truly shat itself. Of course this is basically the moment the Walmart auto center closed. So I'm going to roll out there bright and early at 0630 and be on their doorstep when they open. Hopefully they aren't having a bad morning and don't dick me over or claim 'puter sez yer battery is fine..'... Because it isn't, and the way these things test when they fail can fool you...
If they give me any shit at all, I'm going to Costco and getting the same Group 34 battery for $115 vs $150.
With the price of fuel being what it is, I haven't driven Jeepy a lot lately. I do miss driving and wheeling the Jeep though!
A secondary consideration is that I have a bad axle seal leak on the passengers front that has gotten a lot worse, and a trashed drivers side CV that needs replacing. I put more diff oil in the front end before my last long trip and a lot leaked out. I'm not sure how much, but it was pooling on the LCA, dripping from the front diff tube, and there were splatters on the wheel well liner. So, Jeepy has been relegated to local travel only when necessary.
With the weather more mild now, I'm thinking about tearing into the project on the weekend. I've been accumulating parts for several years and I'm thinking about installing more than just seals, bearings, and CV's. If I drop the front diff I could also throw in a Spartan helical LSD (similar to an Eaton TrueTrac).
I've also got some goodies for the back end too.
What's conspicuously missing are new ring and pinion gears and set up kits. I haven't got those yet, and they're not in the budget any time soon. I want to go with Yukon 4.56 gears (which are doable on the 08-12 KK Liberty, with its JK D30 compatible front end).
So my question is, what would you do?
Option A: Pull the front CV's, replace the front axle bearings and seals, and reinstall CV's. I have a used CV to replace the bad one with the shredded boot. Essentially get the Jeep back on the road in good working order with the least investment of time and energy. Save all the cool stuff for later. Essentially free.
Option B: All of A, plus drop the front diff and install the LSD. Similarly, slap the Torq locker in the rear and replace the rear axle bearings and seals. I gain traction but don't change the stock 3.73 gearing. Plan on regearing later, and try to be patient. Mostly free, except I need about $100 in tools and supplies.
Option C: All of A & B, and also regear to 4.56 at the same time. This is going to take at least $1000 in parts and tools, perhaps more, even if I tackle it myself. In my area it is about $1500 per axle to have a professional regear the Jeep, so that is way out of the budget.
What do you think?
burntkat
L
What do you think?
There's no such thing as overkill, especially with Jeeps... But... Whichever way you go...
Pitter patter, let's get at 'er...
Oh, and.... Regards my battery issue... I have about 1/16" of movement at the NEG terminal.... Telling me there is a broken connection inside the battery, causing my issues. Now I have to find someone at Walmart who understands the battery is bad even though it 'passes' the test.....
LFX1
Update on crank no start, still digging into it. Suggestions Welcome.
Errors:
P0685 ASD/Main Control Circuit
*Cleaned gently the Throttle body, slightly dirty it is stuck shut (may try to find a used one and swap see if makes a difference)
*Swapped ASD Relay with multiple ones
*Verified Fuse is good on ADS 30 AMP Pink.
*Pulled batter positive, and cleaned main connector to fuse box right in front of the batter, pulled box up to pop bottom off to verify no water, or corrosion all sealed dry looked fine, traced wires around looking for fray's and didn't find anything.
I do get the flashing lightening bolt and some said in their case it was failure of throttle body, may grab a used one to swap and see if I get any difference.
Any suggestions.......
burntkat
Got a new battery from Walmart yesterday
They gave me no trouble. I think there was a little bit of E4 Mafia stuff going on there, as I saw the guy had a Veteran pin on his lanyard and struck up a conversation with him....
Damn thing is still doing the cutout at low RPM thing. Not all the time, but often enough for me to be wary at red lights....
Checked for codes this morning. None set but the Bank 2 Catalyst that's been set since I've had her.
The alternator passed the tests I have performed. It's relatively inexpensive - less than 200 bucks... So I may just replace it. Not sure what else this might be.
Years ago I had an XJ that cut out at low RPM. It got so bad I had to put it in neutral to give it some gas at red lights. It turned out to have a dirty IAC (idle air controller) on the throttle body. After cleaning it, no more issues.
LFX1
So far I rulled out crank sensor, I can see RPM's on crank, also ruled out camshaft sensor, I can see cam shaft data go into sync on crank. the throttle body P2112, I got a used throttle body off ebay, but not sure if it was good, seller said it was slightly used looked new a dorman at that, but when I opened it, there was a Amazon return label slip in the box, showing someone bought and returned it to Amazon, as defective. Now I know some people list defective to get free returns, but could be defective as I swapped it and it didn't do anything different so I cleaned original and swapped it back. I did the turn on 5 second gas pedal and slow release to reset it. As for a return on what was suppose to be used, but obviously already returned, I filed a return with eBay see where that goes. I think it was a case of someone buying pallet Amazon returns and just blindly reselling them.
Other issue I found before it got dark is on the ASD port 85 Pin where the ASD Relay plugs in suppose to go to ground on key turn and I can not get that there is a way to manually ground it to see if it cranks and starts I will try that tomorrow. If it will start then the issue is the ASD pin 85 to ground path to PCM is broke. At least what I learned so far.
Only good thing with this process, learning how to use my better scanner a bit more, and crossing fingers, no errors pointing to timing or issues like that so far.
They say if the throttle is in a stuck shut mode, it basically will send signal to the PCM that causes the ASD to trigger which would create the issue I am having. But short of having another throttle body to try, im going to try the manual ground.
If anyone has similar crank no start with codes like mine let me know. I will keep updating so others can benefit if I find a resolve.
Errors:
Circling The Drain
I've probably had my share of codes but I have never seen any of those. Good luck - I hope someone can help you out.
@LFX1 this is going to sound insane, but I *JUST* worked that exact problem/code (P0688) on a fiat 500e I have here for repair.
relay checked fine. fuse it feeds checked fine, but only at the test points. turned out the fuse blades had some kind of schmoo/corrosion on them that prevented power from LEAVING the fuse. find the fuse downstream of the relay, replace it with a fresh one, check the terminals the fuse plugs in to.
LFX1
Hopefully this is the final Update. Everything was with the ASD, which can lead you in many directions since it controls so much. So finally this AM with a fresh charge on the battery, I was able to Jump pins on ASD Pin 87 and Pin 30, turn key totally started first time Woohoo, this proved everything down stream injectors, engine and as I knew cam timing and crank timing were good, felt good to hear the engine start. So from there it lead to wire, broke or corroded, or the key ignition switch being broke turning enough to start but not enough to push the pin to signal the PCM to pass power on the ASD. So at this point I had already looked a fuses, and the wiring underneath the fuse box . Decided to look at wiring again one more time.
The ASD Relay is all the way at the drivers side upper corner which is pain to tilt up. All looks good, tilt little hire there it was one plug looked little dusty I didn't see before, that's when I cut the electrical tape a little more and tilted up the fuse box gently, and touched the wire with my test light (battery was disconnected) sure enough the wire moved to easy looked up in there with my head light on, and sure enough it was broke right at the compression of the connector. Only one I can see that looks like that strange.
Used some compressed air to blow it out the slot, wire is nice an long as was looped around so I shouldn't have to add to it. Getting the connector out with out the proper tool a bit challenging, finally got it out with my small poker enough to release the lock and popped out the bottom.
Now the hard part is to is to find the proper blade connector, these things look stainless, and they have the divot to lock in when pushed in, hopefully I didn't f'up the lock and it locks in. Found a Dorman 85377 kit with 2 of each size blades, actually say's it for ford the largest one looked like it might work but may be to narrow, so I didn't get it it was $12 I would only use one size if it worked. I have wire blades the blue yellow and red ones, so not over paying for one unless its the correct one. If anyone knows where to get the ones for Jeep let me know. I think it's a Metri-Pack 630 female. Worst case scenero I make the wire long for slack, make the top side hole little larger and fish it through to put it on the relay manually then let it drop down in, I know it's backwoods way, but if the lock that holds it is craped out, not really looking at buying a whole fuse box to replace one bad slot. Metri-Packs are on Amazon if I get it and it works, I'll post here.
Lessons Learned:
1. The engine management systems can cause lots of issues, so right tools to drill down saves problems/time, in the past I would probably replace sensors, with right scanner to rule those out, let me move on.
2. When checking fuses, check them one at a time front to back up and down, if I would caught this the first time I had opened up bottom of the fuse box, I would of saved time. It was hard to see and is in the worst possible spot. Take your time and work through the troubleshooting.
3. Codes helped a bunch to narrow down, and what to rule out. Follow the process.
4. Don't give up. Work your plan, and check stuff off you did.
This sort happened at the worst I was anxious to have it running and not taking my time. My truck is getting the gas tank bracket welded so I don't have it here to drive, and our small car started making a odd noise possibly CV axle, so not having my Jeep running, really was sucking.
So far I ruled out crank sensor, I can see RPM's on crank, also ruled out camshaft sensor, I can see cam shaft data go into sync on crank. the throttle body P2112, I got a used throttle body off ebay, but not sure if it was good, seller said it was slightly used looked new a dorman at that, but when I opened it, there was a Amazon return label slip in the box, showing someone bought and returned it to Amazon, as defective. Now I know some people list defective to get free returns, but could be defective as I swapped it and it didn't do anything different so I cleaned original and swapped it back. I did the turn on 5 second gas pedal and slow release to reset it. As for a return on what was suppose to be used, but obviously already returned, I filed a return with eBay see where that goes. I think it was a case of someone buying pallet Amazon returns and just blindly reselling them.
Errors:
burntkat
Also, use contact cleaner any time you investigate a fuse or relay connection. This should be second nature... If you touch it, clean it.
burntkat
Still having the cutouts at idle. Not all the time, but most of the time *when the engine is at temp, thus the alternator is hot*. When at ambient, it doesn't cut out at idle...
*this, as we say in the business, is a clue*
The alternator test I ran was also on a cold alternator. Rolled the dice, bought a new alternator. Installed it this evening in the rain by headlight. (because really, why wouldn't I after two days with plenty of dry weather and light.) Took about 20 minutes to do the job. I haven't driven yet, but I fully expect some cutouts tomorrow (I always get this behavior for about 10 miles after removing power to the vehicle, aka taking the pos lead off the battery when doing electric work. The true story will be told on the way home from work tomorrow - I live 9 miles from work.
Noticed a few days ago that the WP has a weep out of the indicator hole. Replacing it tomorrow night. Now I think, I should probably check and see if that WP is new. I can't imagine I didn't replace it when we rebuilt the top end about 2 years ago....
LFX1
So contact cleaner, but is there any other spray we can use to protected it from any moisture?
