Looks good in that engine bay!
That’s fantastic! I had to check more closely if that was km or miles, and it’s actually miles. What year is your KJ?Another milestone reached.... After a number of issues in late 2024& early 2025 it's been very quiet ever since. I hope I didn't just jinx it with this postYou must be registered for see images attach
2005That’s fantastic! I had to check more closely if that was km or miles, and it’s actually miles. What year is your KJ?
There are threads on here for installing an EVIC...Yeah I will figure it out. I built a SFA swapped 89 S10, with a 5.7 V8 and D44a front and rear.... I'll figure this out.
As requested @burntkatPics?
yikes! I’ve seen this before. Incidental alternator seizure. The tensioner is constant tension, so while it’s possible, it’s unlikely.not on the jeep, but the minivan...
so first, parked it one day after using it, no issues.
came out like 2 weeks later and, wouldn't start.
charged the battery, no joy.
could hear the starter solenoid clicking.
tried to bar the engine over, no joy.
checked to see if it was hydrolocked... nope.
poked around and discovered the braided line on the starter was smoked. age and corrosion had killed it.
fine, put in a new starter. cranked over and fired.
sounded like hell though. squealing like the dead.
finally say the alternator was NOT turning... then the belt snapped.
just finished putting in the alternator a bit ago... and discovered the belt tensioner is toast.
got that on order now.
wondering if it's possible that... the tensioner failed, the belt was slipping enough (I could occasionally hear some squealing, but it would go away) that it created enough heat on the alternator pulley that it smoked the internal bearings, locking it up, which prevented the weakened starter from cranking the car and smoked the weakened braided connection.
No. The D30a diff is proprietary. I believe both the carrier and rhe ring gear, and quite probably the pinion. This is why a R&P kit for a D30a in a Liberty is approx $800 (new), just for the parts."4.10 Gears w/lunchbox locker for Dana 30 installed briefly in a Jeep CJ7 Dana 30 front differential"
will that working in the 30a in the liberty?
I used the Eaton Detroit trutrac part number to cross reference and find the Dana 30 from a JK and our strange little 30a would take the same part number. Using this info I got the Spartan Helical that most sources say will not fit the KJ but fits a JK and have been running it for a few years now. You'd have to do your own research for the CJ7 part you're looking at."4.10 Gears w/lunchbox locker for Dana 30 installed briefly in a Jeep CJ7 Dana 30 front differential"
I believe he's talking about swapping the chunk in it's entirety, gears and all. .. Or am I wrong?I used the Eaton Detroit trutrac part number to cross reference and find the Dana 30 from a JK and our strange little 30a would take the same part number. Using this info I got the Spartan Helical that most sources say will not fit the KJ but fits a JK and have been running it for a few years now. You'd have to do your own research for the CJ7 part you're looking at.
I've had problems with NGK coils. They started going bad after 20k miles. Definitely recommend replacing them with a different brandHaving a recurring, intermittent, stutter. Feels like fuel cut like you'd get when you exceed max RPM. But it's around 4k. I have new NGK coils installed. Issue has been extremely rare, dating from before I installed the new coils. Plugs are NGK as well, aboit a year old. No codes other than a recurring catcon on bank 2, IIRC..any ideas?
Thought we were talking about the lunchbox locker and carrier. The ring and pinion will not fit, no if's ands, or buts.I believe he's talking about swapping the chunk in it's entirety, gears and all. .. Or am I wrong?
This thread has so many things going on, I don't know what I'm replying too.Thought we were talking about the lunchbox locker and carrier. The ring and pinion will not fit, no if's ands, or buts.
