blue_kjR417
Platinum Renegade
I want to get a set of BFGoodrich All Terrain T/A KO's, I'm currently running P235/70R16's Goodyear Fortera Triple Tread's, what is biggest size I could run without a lift and the tires not rub?
I'd like to mention that when people say with/without rub, it depends on the tire you select. I ran 245/70R16 Toyo Open Country A/Ts on a Lowered Lib with no rubbing.
April 12th 2002 Jeep lowered the KJ by 3/4" because some idiot at car and driver magizine rolled a 2wd KJ on a test course that could not be replicated.What does pre lowered and lowered mean?
I am currently running 245/70/16 Destination A/T's on MOAB rims that are an inch wider (16x8 as opposed to 16x7 stock) and stick out 1/2" more (5" BS as opposed to 5.5" stock) more than the stock rims.
On a stock suspension with the pinch weld pounded front fog door portion of the fender pushed forward, I am still getting some rubbing just before full lock.
-Ryan
EDIT: TJKJ beat me to the Lowered and Pre-lowered
Why not?And, it looks great judging by the pic in your sig. I'd love to throw some MOAB's on mine, but can't justify the cost.
Why not?
You can get a set of MOAB's for dirt cheap here in CO,I've seen many sets of 5 for anywhere from $200-$500,some with pretty good tires mounted on them.Way cheaper then buying other rims besides black steel rims.
